PIPE ENGINEER
VARD is one of the major global designers and shipbuilders of specialized vessels. Headquartered in Norway and with approximately 10,000 employees, VARD operates eight strategically located shipbuilding facilities, including five in Norway, two in Romania, one in Brazil and one in Vietnam. Through its specialized subsidiaries, VARD develops power and automation systems, deck handling equipment, and vessel accommodation solutions, and provides design and engineering services to the global maritime industry.
A long term career & attractive remuneration will be offered to successful candidates. Applications must be in English & should include cover letter, reference number, CV, certified copies of qualifications, required salary & references & should be forwarded before 10 November 2023 to Ms. Pham Thi Thu Ha – HR Advisor - Recruitment, VARD Vung Tau Limited, Dong Xuyen Industrial Zone, Rach Dua Ward, Vung Tau City. Or Email: vietnam.hr@vard.com
You can find out more about us at www.vard.com
Company Benefits:
  • Salaries are reviewed & adjusted annually;
  • A long term career at a Professional and Dynamic working environment;
  • Training to be provided locally and/ or internationally.
  • Make engineering drawing, design and perform design analysis;
  • Check of design, drawing to comply with standard, specification and Class rule;
  • Take responsibility for drawing management, record, feedback and follow up all relevant production documentation as assigned;
  • Be responsible for internal QA process, materials take off, weight attributes;
  • Technically conduct and support production as relevant;
  • Comply with the national laws, regulation, international standard including ISO9001, ISO14001, ISO45001/ OSHA18001, SA8000 or any updated and valid standard on management system, Company regulation.
Qualifications Required:
  • Bachelor degree within Naval, Marine or Mechanical engineer.
Other Requirements:
  • Have knowledge and experience on Piping system;
  • Shipyard or heavy industries experience (Power plant, refinery);
  • Production support orientation (consider the workable of the design) experience;
  • Minimum cost orientation design experience;
  • Fluent in written and spoken English and Vietnamese;
  • Strong team mind-set, teamwork skills, understand standardization activities.
