CYBER OIL/ PVD INVEST TUYỂN DỤNG GẤP MECHANICAL TECHNICIAN SỰ CHO DỰ ÁN VỚI KHÁCH HÀNG:
MECHANICAL TECHNICIAN (Vietnamese)
SPECIFIC ACCOUNTABILITIES:
Reporting to the Lead Mechanical Technician, accountabilities include:
(Skills required to accomplish this role effectively)
Phone: 0359 714 637
Thanks for your attention and we look forward to hearing from you soon! If you are selected for an interview, you can expect for a phone call from us!
- Maintain integrity and perform safe and efficient maintenance of all mechanical systems and equipment on CPP and wellhead platform in accordance with established procedures.
- Understand and follow all rules and procedures.
- Report all hazardous conditions, near misses, accidents and system breakdowns.
- Demonstrate the culture that no job is so routine or urgent that it cannot be done safely.
- Use CMMS to control of daily mechanical maintenance activities and report data as required.
- Adherence to Control of Work system while carrying out all activities.
- Gathering of data in support of equipment condition monitoring.
- Willingness and flexibility to be trained in all aspects of CPP operations.
- Willingness to train and be part of an offshore emergency response team.
- Progress competency as per Personal Assessment Record (PAR) in Casys.
- Mechanical Technologist Certificate in Mechanics or equivalent.
- 3 years related experience in an industrial maintenance environment (preferably in the offshore or petrochemical / refinery industry).
- Working knowledge of regulatory and industry codes applicable to the mechanical discipline.
- Working knowledge of preventive and predictive maintenance, condition monitoring and with the application of computerized maintenance management systems.
- Familiarity with the theory and practice of rotating equipment and vibration analysis.
- Experience with the operation and maintenance of gas turbine driven generators, diesel engines, multi-stage centrifugal pumps and compressors, HVAC systems, hydraulic systems and associated auxiliary mechanical equipment.
- Knowledgeable and experienced in static mechanical equipment including pressure vessels, valves, heat ex-changers, and other process equipment of offshore topside.
- Hands-on skills in use of workshop’s equipment including repair and fabric works.
- Ability to read relevant technical drawings and piping specifications.
- Teamwork skills / behaviours which support a team based organization.
Phone: 0359 714 637
