PVTRANS OFS
Member
PVTrans Oilfield Services is searching for Pumpman to join Chim Sao project as follows:
Specific Accountabilities:
• Performs, as directed by the LCO, cargo operations, including checking that cargo and ballast systems are correctly set as per the cargo plan.
• Assists the LCO in all tasks associated with cargo preparation, the handling of cargo and ballast, including topping off and stripping / educting of cargo tanks.
• Participates in Crude Oil Washing Operations
• Monitors distribution and Control of Inert Gas to Cargo and Ballast tanks.
• Responsible under the direction of LCO’s for the maintenance and proper operation of deck and pump room machinery, equipment and valves
• Rebuilds valves and pumps
• Corrects leaks in the cargo system
• Repack valves and glands
• Lubricates parts, such as glands, bearings and reach rods.
• To ensure that equipment and material instructions are followed.
• Identify, assess and mitigate hazards to safety – both personal and process, that present a risk to safety on board the FPSO
• Indicates areas or equipment of concern to line supervision and area authority.
• Enters Cargo oil and ballast tanks and conduct maintenance on cargo valves, piping and hydraulic systems as necessary
• Reports all potential or actual defects in cargo equipment to the LCO and maintain a full and accurate inventory of the deck store and spare parts at the required levels by requisitioning spares through the LCO.
• Carries out tank gauging and sampling as required.
• Stops work that is unsafe or likely to cause damage.
• Assists with general duties - mooring operations, rigging, storing and domestic duties, as required
• Monitors and Control Shuttle Tanker Operations during Cargo transfers
Key Competencies preferred
· Minimum of 7 years’ experience (seagoing) on crude oil tankers (VLCC experience preferred).
· Suitable experience as Fitter in the engine room with appropriate qualifications.
· Working knowledge of Permit to Work systems
· Working knowledge of all safety and emergency systems and equipment on board
· Knowledge of safety practices and policies such as handling of flammable / dangerous liquids, confined space entry procedures, ships’ tag-out system and process isolations.
Working location: Offshore (FPSO Lewek Emas – Chim Sao project)
Application Deadline: 22th March 2022
Applicable to Vietnamese employees only
Send your resume to pvtransofs-recruitment@pvtrans.com or contact us at +84 254 357 6669 - Ext: 201
