The weakest link in the design of high-efficiency drilling operations is the readiness of cutting tool users/machining operation designer/planners and cutting tool manufacturers plus the lack of relevant research works on the modern hole making operations. This book addresses the most important issues in drilling operations, and is designed to familiarize application specialists with properly defined basic concepts, terminology, and essentials of drilling
Content: Drilling System
Tool Failure as a System Problem: Investigation, Assessment, and Recommendations
Tool Materials
Twist and Straight-Flute Drills: Geometry and Design Components
PCD and Deep-Hole Drills
Metalworking Fluid in Drilling
Metrology of Drilling Operations and Drills
Appendix A: Axial Force, Torque, and Power in Drilling Operations
Appendix B: Tool Material Fundamentals
Appendix C: Basics of the Tool Geometry.
Abstract: The weakest link in the design of high-efficiency drilling operations is the readiness of cutting tool users/machining operation designer/planners and cutting tool manufacturers plus the lack of relevant research works on the modern hole making operations. This book addresses the most important issues in drilling operations, and is designed to familiarize application specialists with properly defined basic concepts, terminology, and essentials of drilling
LINK DOWNLOAD: HERE
Tool Materials
LINK DOWNLOAD: HERE
