PVTRANS OFS
PVTrans OilField Services is a professional provider of maritime transportation and services to the oil and gas industry in Viet Nam and abroad (FSO/FPSO, O&M...). We are now looking for 4th Engineer to join our team.
The successful candidates will be required to undertake the required job duties.
Minimum Competencies:
Working location: OFFSHORE- FPSO - Vungtau, VietNam
Application Deadline: As soon as possible
Please email resume and any references to HR Department at:
pvtransofs-recruitment@pvtrans.com
- Marine Engineering with Tanker Class 2 Endorsement, Inert Gas, COW and MED 3
- Minimum of 2 year experience as 4th Engineer on Tanker or motor vessel
- Steam Ticket
- Extensive experience required in maintenance of Boilers and other FPSO Utility Equipment
- Computer literate.
- Have experience of working using Permit to Work systems.
- Proficient in English both written and oral.
- Effective communication skills.
- Work under direction of 2nd Engineer and reporting directly to the 2nd Engineer
- The 4th Engineer’s duty and responsibility is to maintain and ensure maintenance of machinery in engine room assigned to him including, but are not limit:
- Sea water Booster pumps for WIP.
- SWL Pumps
- Sea water cooling pump of STG 9.2 MW,
- HV STG condensate pumps,
- Fresh water cooling pumps,
- Bilge and Ballast Pumps
- Engine room bilge pumps
- Sewage treatment plant system
- Galley / Accommodation grey water drain system in Engine room
- Lube oil tank and piping system,
- Lube Oil Purifiers,
- Bunkering MDO and FW system.
- Portable water system
- HP & LP Boiler chemical dosing system
- All the relevant system
- Immediately report to 2nd Engineer for anything abnormal of machinery and equipment under his responsibility.
- To prepare P.T.W and submit to Utility Supervisor for approval at least 04 hours prior commencement of afternoon daily meeting.
- To carry out PLMs and CRM as per 2nd Engineer for requirements of maintenance and repair.
- To carry out routine maintenance and repair work as directed by 2nd Engineer.
- To monitor (inventory, raise PR) spare part stocks of machinery /equipment under his control well inventoried and updated all time.
- Maintain and update inventory of all Lube Oil & Grease, Freon.
- Take distilled water and portable tank daily sounding.
- To be incharge of MDO bunker tanks under Utility Supervisor’s instruction.
- To support dayshift / nightshift operation together with LUO when required.
