Run Time: 0.000516
Run Time: 0.000134
WHERE (`xf_thread`.`thread_id` = '10328')
Run Time: 0.000635
WHERE (`xf_post`.`thread_id` = 10328) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.000716
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 2 | Using index condition; Using where; Using filesort |
SELECT `xf_attachment`.*, `xf_attachment_data_Data_1`.*
FROM `xf_attachment`
LEFT JOIN `xf_attachment_data` AS `xf_attachment_data_Data_1` ON (`xf_attachment_data_Data_1`.`data_id` = `xf_attachment`.`data_id`)
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (11169))
ORDER BY `xf_attachment`.`attach_date` ASC
Run Time: 0.000231
SIMPLE | xf_attachment | ref | content_type_id_date | content_type_id_date | 31 | const,const | 2 | Using index condition |
SIMPLE | xf_attachment_data_Data_1 | eq_ref | PRIMARY | PRIMARY | 4 | oilgasvn_db.xf_attachment.data_id | 1 | |
- XF\Mvc\Entity\Finder->fetch() in src/XF/Repository/Attachment.php at line 241
- XF\Repository\Attachment->addAttachmentsToContent() in src/XF/ControllerPlugin/Thread.php at line 46
- XF\ControllerPlugin\Thread->fetchExtraContentForPostsFullView() in src/XF/Pub/Controller/Thread.php at line 110
Params: 10328
Run Time: 0.000074
Params: 0, ��$
Run Time: 0.000093
INSERT IGNORE INTO xf_session_activity (
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?)
Params: ��$, XF\Pub\Controller\Thread, Index, valid, thread_id=10328, 1715820790, , 0, ��$
Run Time: 0.000068
Run Time: 0.001418
Run Time: 0.000387
WHERE (`xf_session_activity`.`user_id` = 4824) AND (`xf_session_activity`.`unique_key` = '4824')
Run Time: 0.000117
WHERE (`xf_thread`.`thread_id` <> 10328) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`node_id` = 46) AND ((`xf_thread`.`title` LIKE '%Opportunity%') OR (`xf_thread`.`title` LIKE '%in%') OR (`xf_thread`.`title` LIKE '%Malaysia%'))
Run Time: 0.000866
SIMPLE | xf_thread | ref | PRIMARY,node_id_last_post_date,node_id_sticky_state_last_post,node_id_sticky_state_vote_score | node_id_last_post_date | 4 | const | 74 | Using index condition; Using where; Using filesort |
Run Time: 0.000231
Run Time: 0.000592
Run Time: 0.003804
bytes_sent | 17473 |
bytes_received | 477116 |
packets_sent | 172 |
packets_received | 2098 |
protocol_overhead_in | 8392 |
protocol_overhead_out | 688 |
bytes_received_rset_header_packet | 405 |
bytes_received_rset_row_packet | 174 |
bytes_received_prepare_response_packet | 159535 |
bytes_received_change_user_packet | 316327 |
packets_sent_command | 85 |
packets_received_rset_header | 45 |
packets_received_rset_row | 30 |
packets_received_prepare_response | 1832 |
packets_received_change_user | 161 |
result_set_queries | 26 |
ps_buffered_sets | 26 |
ps_prepared_once_executed | 27 |
rows_fetched_from_server_ps | 135 |
rows_buffered_from_client_ps | 135 |
implicit_free_result | 25 |
proto_binary_fetched_bit | 788 |
proto_binary_fetched_short | 1356 |
proto_binary_fetched_int24 | 508 |
proto_binary_fetched_bigint | 3657 |
proto_binary_fetched_decimal | 73 |
proto_binary_fetched_date | 35 |
proto_binary_fetched_json | 1945 |
proto_binary_fetched_blob | 816 |
com_stmt_prepare | 28 |
com_stmt_execute | 28 |
com_stmt_close | 27 |
bytes_received_real_data_ps | 311309 |
