Run Time: 0.000518
Run Time: 0.000169
WHERE (`xf_thread`.`thread_id` = '11361')
Run Time: 0.000760
WHERE (`xf_post`.`thread_id` = 11361) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.000781
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 5 | Using index condition; Using where; Using filesort |
SELECT `xf_attachment`.*, `xf_attachment_data_Data_1`.*
FROM `xf_attachment`
LEFT JOIN `xf_attachment_data` AS `xf_attachment_data_Data_1` ON (`xf_attachment_data_Data_1`.`data_id` = `xf_attachment`.`data_id`)
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (12304))
ORDER BY `xf_attachment`.`attach_date` ASC
Run Time: 0.000298
SIMPLE | xf_attachment | ref | content_type_id_date | content_type_id_date | 31 | const,const | 1 | Using index condition |
SIMPLE | xf_attachment_data_Data_1 | eq_ref | PRIMARY | PRIMARY | 4 | oilgasvn_db.xf_attachment.data_id | 1 | |
- XF\Mvc\Entity\Finder->fetch() in src/XF/Repository/Attachment.php at line 241
- XF\Repository\Attachment->addAttachmentsToContent() in src/XF/ControllerPlugin/Thread.php at line 46
- XF\ControllerPlugin\Thread->fetchExtraContentForPostsFullView() in src/XF/Pub/Controller/Thread.php at line 110
Params: 11361
Run Time: 0.000066
Params: 0, �=�
Run Time: 0.000101
INSERT IGNORE INTO xf_session_activity (
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?)
Params: �=�, XF\Pub\Controller\Thread, Index, valid, thread_id=11361, 1714485591, , 0, �=�
Run Time: 0.000086
Run Time: 0.000613
Run Time: 0.000345
Run Time: 0.000135
WHERE (`xf_thread`.`thread_id` <> 11361) AND (`xf_thread`.`discussion_state` = 'visible') AND (`xf_thread`.`discussion_type` <> 'redirect') AND (`xf_thread`.`node_id` = 31) AND ((`xf_thread`.`title` LIKE '%Hạ%') OR (`xf_thread`.`title` LIKE '%thủy%') OR (`xf_thread`.`title` LIKE '%thành%') OR (`xf_thread`.`title` LIKE '%công%') OR (`xf_thread`.`title` LIKE '%giàn%') OR (`xf_thread`.`title` LIKE '%BK%') OR (`xf_thread`.`title` LIKE '%Thiên%') OR (`xf_thread`.`title` LIKE '%Ưng%'))
Run Time: 0.004466
SIMPLE | xf_thread | index | PRIMARY,node_id_last_post_date,node_id_sticky_state_last_post,node_id_sticky_state_vote_score | post_date | 4 | | 31 | Using where |
Run Time: 0.000251
Run Time: 0.000529
Run Time: 0.001985
bytes_sent | 17845 |
bytes_received | 490573 |
packets_sent | 172 |
packets_received | 2100 |
protocol_overhead_in | 8400 |
protocol_overhead_out | 688 |
bytes_received_rset_header_packet | 405 |
bytes_received_rset_row_packet | 174 |
bytes_received_prepare_response_packet | 159535 |
bytes_received_change_user_packet | 329784 |
packets_sent_command | 85 |
packets_received_rset_header | 45 |
packets_received_rset_row | 30 |
packets_received_prepare_response | 1832 |
packets_received_change_user | 163 |
result_set_queries | 26 |
ps_buffered_sets | 26 |
ps_prepared_once_executed | 27 |
rows_fetched_from_server_ps | 137 |
rows_buffered_from_client_ps | 137 |
implicit_free_result | 25 |
proto_binary_fetched_bit | 826 |
proto_binary_fetched_short | 1409 |
proto_binary_fetched_int24 | 529 |
proto_binary_fetched_bigint | 3770 |
proto_binary_fetched_decimal | 72 |
proto_binary_fetched_date | 35 |
proto_binary_fetched_json | 1999 |
proto_binary_fetched_blob | 857 |
com_stmt_prepare | 28 |
com_stmt_execute | 28 |
com_stmt_close | 27 |
bytes_received_real_data_ps | 324605 |
