BEPA Engineering cần tuyển Kỹ Sư Xây Dựng - Chuyên Gia Revit
Construction Engineer - Revit Specialist
Working in: Dong Xuyen IP, Vung Tau city
Salary: 1,000USD to 1,400USD
Job Description
• Your Challenge
You will be the executing part in realizing the dreams and thoughts of the architects – and you will participate in the total process from developing of masterplans, building design and detailed solutions in the construction of the building.
• Your responsibility
From the Danish architects’ ideas and drawings, you will create the technical layout and documentation of the buildings and the installations in Revit.
• Your tasks
Your tasks will be to develop:
Electrical systems and installations
IT infrastructure
Water, toilets and drains
HVAC-systems
Bathrooms, pools, fitness and spa
Sewerage
And other installations such as garage facilities, elevators and others.
Your experience and skills:
• You are an experienced engineer specialized in buildings, building installations and construction and you have worked several years with relevant projects in these areas.
• You consider yourself a specialist in Revit, Tekla, AutoCad and SolidWorks - and on sight you can act as a supervisor to colleagues and customers.
• You work systematically and customer-oriented, and you must thrive in a dynamic environment where quality and deadlines always have the highest priority.
• You must be able to work in English at a high professional level.
If you feel that you are well suited to the above opportunity, please send your CV to Ms. Linh Email: linh@bepa.dk
