AlphaNDT provides NDT and PWHT services for Inspections & Maintenance of Gas-Power-Fertilizer Plants, Ship Building and Repair, Mechanical & Civil Engineering, Onshore and Offshore Oil & Gas Facilities.
Currently, we have high demand for the following positions:
Positions:Non-destructive Testing Inspectors (NDT Inspectors)
Quantity: 15 posts
Required education and qualifications:
Quantity: 15 posts
- Bachelor’s Degrees or equivalent (Majors: Electrical/Electronics/ Mechanical/Industrial / Petroleum /Automatic Control/Marine Engineering);
- Good English;
- Excellent Health;
- Self-motivated, diligent, eager for learning.
- Serve as Non-destructive Testing Inspector (NDT Inspector) in welding quality inspection, tank and piping corrosion survey, hull thickness gauging;
- (Referred SOW: Welding testing to detect defects inside and on surface of the welds, corrosion survey; interpret and evaluate test results in accordance with applicable codes, standards, specifications, or procedures; produce testing reports, etc.)
- Perform Non-destructive Testing at height using IRATA Rope Access methods.
- Experienced in NDT/Rope Access is a priority;
- Otherwise, candidates will be trained by Company for all the testing methods.
- Work location: Oil & Gas and Power Plants/Steel fabrication workshop/Marine and Civil Constructions in Ba Ria - Vung Tau Province; offshore Oil & Gas facilities.
- Salary: under negotiation.
- This recruitment notice is valid until the required staffs to be sought.
- Please scan your application (CV, certificates, degrees, ID card, health check report) and send to email address: hoa-vm@alpha-ndt.com, HP: 0902 366924; or directly submit to the Receptionist of AlphaNDT at Road 11, Dong Xuyen IZ, Vung Tau City.
